How do you guy's feel about this Install
Customer wants a 100 amp generator with ATS install and the only way to get service from the ATS at service area to the GEN is either [ 1 ] run in conduit under the crawl space an supported from the rafters under neath and then onto the GEN which is on the opposite end of the house some 90 feet away [ 2 ] the other way would be to trench 8 feet from service area to under a wooden deck that's about 4 ft 8 in off the ground run in conduit and also supported from the rafters below an then onto the Gen.
All copper conductors an either sch 40 or 80 pvc with disconnect at gen , the inside work well that's another story.
Anyone see any issues with this Install
Thanks in Advance
Thanks in Advance
