3rdgenerationelectrician
SITUATION
I currently work for a company that is manufacturing Electric Vehicle Supply Equipment (EVSE) used for Level 2 charging (240V, 40A) for the consumer EV's to be released this year. Our company has been tasked to provide a national installation network of electrical contractors to install the EVSE product. Part of our responsibility is to provide assessment of Level 1 charging (120V, 20A) in the area the customer will be charging the vehicle. The car manufacture will supply the car with a cord set that is GFCI protected.
PROBLEM
If the cord set is GFCI protected and the outlet requires GFCI protection for this location this will cause tripping.
QUESTION
What options are available to eliminate this problem, can a twist lock receptacle be used on the line side of the GFCI outlet (assuming a GFCI breaker was not used)?
What other options may be used?
PROBLEM
QUESTION
