- Lockport, IL
- Retired Electrical Engineer
Short version of question: Can galvanized rigid steel be direct-buried in the dirt below the bottom slab of a building, without having any corrosive protection (such as PVC coating) added?
Longer version: Which of the following does 344.10(B)(1) mean?
- OK in concrete. OK in dirt. OK in corrosive area, but only if protected against corrosion.
- OK in concrete, but only if protected against corrosion. OK in dirt, but only if protected against corrosion. OK in corrosive area, but only if protected against corrosion.
