I normally connect the outdoor transformer neutral to the transformer ground loop and to the building ground loop and I connect the neutral to the ground bus at the service entrance equipment. Per NEC 250.24(A)(2) I also need to make this connection outdoors. Per 250.6(A) to avoid objectionable currents I MUST NOT connect the transformer neutral/transformer grounding system to the building ground loop. Question - If the service entrance raceway is metal and is connected to the transformer enclosure should the connection between the transfomer enclosure and the transfomer neutral be made?
