mltech
- Ft. Lauderdale
I have a new home going up that requires an overhead 400amp service attached to a remote garage 120' away from the main house it supplies. There is a 100kw generator with service rated transfer switch between the meter can and 400MDP. Can I run a seperate conduit to the home in the same trench as the 400 amp feeders for the uffer ground and cold water bond? My goal is to use the Transfer switch as the single point of bonding the service, drive a ground rod (or 2) and then hit the house.
Any thoughts are appreciated.
Thanks,
Mike
Thanks,
Mike
