100208-2333 EST
At Dana Columbia on a production test machine for noise and other tests of the Ford Aerostar transfer case we used a service that did laser alignment of a 50 HP DC motor coupled to a shaft in a sleeve bearing. This was quite successful. Also had to dynamically balance the motors because this was a vibration sensitive test, there were three motors, one for each shaft. The total test time was probably about 40 seconds. The motors had to be rapidly ramped up and down, 0 to 2500 RPM, in synchronization with different torque loading.
In a different application, non rotating, a pinion position machine at Ford Sterling laser alignment was tried, but the dial indicator method worked better.
In any event it takes the skill of an experienced person, most likely a machine repairman or toolmaker. Millwrights are usually more for the rough stuff. It will depend upon the plant what skill levels exist.
Note, Bill is a highly experienced machine repairman so his comments are more important than mine.
