gulkhan123
Q: Dividing BTUH by 3413 gives to KW. Is this mechanical or electrical KW? I mean is this the electrical KW the machine will consume?
This is cooling capacity of the HVAC equipment not electrical load. This is S.I unit for Cooling capacity just as FPS unit which is BTulh.
The same unit is used in calculating electrical load KW i.e. we usually not use BTu/h for electrical loads as we don't have to remove heat from any space but we have to supply power to the equipment. Although electrical loads cause heating effect too but this effect is not significant here. So we use KW unit for Electrical load.
I had faced same problem like you but I found a solution for this. It is night here 2moro in the morning I will go Office I have the solution I will inform you.
A electric nickel chrome heater element produces 3.4 BTU/Hour
The very efficient mechanical refrigeration compressor produces 8.533 BTU/Hour+/-
I had a 4 ton unit 10 SEER that pulled 28 amps. That's 28x240 = 6720 kva /4ton = 1.7 kva per ton
One ton of frig.=12000 BTU/hour
1 watt=8.533 BTU/hour compressor
4 tons x 12,000=48,000 BTU/hour
48,000/8.533=5,625 watts 1.4 kw per ton 1.75 kva per ton
5,625 w/240 volts=23 amps more efficient machine
If you include the SEER, then you can do it another way. SEER is defined as the heat transferred per unit of energy, that is in BTU/watthour.
P = AC load/SEER
For your 4 ton unit and SEER = 10,
P = (48,000 BTU/hour)/(10 BTU/watthour) = 4,800 watts,
then throwing in PF,
I = P/(VxPF) = 4800W/(240V x 0.8) = 25A 1.2 kw per ton or 1.5 kva per ton
This is comparable to the other result.
Sorry did not see this post. Consumption is hard to define because you would have to know the insulation factor, area of the room(s), temp differential. But as a ball park figure use 33.33% duty cycle in a 24 hour period or 8 hours. So 4.8 Kw x 8 Hours = 38.4 Kwh per day usage. To figure the load you would need the PF so if it was say .8 then 4.8 KW / .8 = 6 KVA.Thanks Bob. Excellent calculation. But I just want to know what do we conclude from this? I mean what is the relation between a HVAC unit(BTUH) and the electrical power it consumes? Or, in other words, if we know the BTUH of an HVAC unit, what would be the input elect. power consumption?thanks
P = AC load/SEER
