max current for 125A panel?
lat1
today i was working in a print shop adding a couple of circuits for them. while looking around to find the best place to pull power from i found a 125A MDP 120/208 panel (fed from a meter) that seemed odd to me. the accumulated loads, (100A heat press, 40A flash table, and 2- 30A compressors) sometime run simultaneously. i didn't look at the name plates on the various machines, but even if all the breakers were loaded at 70% there would be a 140A load on a 125A panel. the main has never tripped in 18 months. is this installation ok? i wouldn't be as concerned if the loads were not sometime continous?
Buck Parrish
NC & IN
Well obviously every place is different. Esspecially with the 100 amp press. Perhaps the name plate was considering the most it would pull. But...
I wired a dentist office on a 100 amp 3 phase panel.
3 phase has a better load capacity then single phase.
125 is even better as 100 amp 3 phase seems to be common in small retail stores.
jim dungar
Wisconsin
PE (Retired) - Power Systems
You must look at the loads themselves, not the breakers feeding them.
Until that is done you have no hope of determing if the installation is correct.
