If I have a fan being driven by a motor and the motor is connected to the fan by a belt then I would think that by increaseing the speed of the fan by inreasing the belt ratio then the current drawn from the motor would be increased. Do others agree? Here is my reasoning. (We are assuming that head pressure stays the same.)
First I would think that the current would have to increase by the simple fact that because we change the belt or gear ratio to increase the fan speed, we are reducing the avalaible torque at the fan. Therefore in order to keep the same torque requirement at the fan at the increased speed the motor will have to provide an increased torque, and it is this increased torque that will be reduce by the new gear ratio to provide the origonal torque requirement. This increased torque means increased current to the motor.
Secondly since the fan torque increases with the square of the speed the fan torque requirement at the fan will increase. My above paragraph stating that the motor torque would increase with speed increased was based on the fact that the torque would increase linerally for a constant load torque at the fan. But now since the load torque is increasing exponentially I would assume that the motor torque would not only have to increase exponentially for the load torque increase, but would also have to double for the speed increase.
So esentially if you took the exponential fan load torque curve and shifted it upwards by double the amount would this represent the required torque from the motor with the new speed produced by increasing the gear ratio?
Am I on the right track with this or am I way off?
