chevyx92
- VA BCH, VA
Scenario: (7) 5-TON RTU's all 3 Phase 208V, nameplates MCA is 29.8 and the MCB/MFS is 45. The RLA (I assume this is "Running Load Amps") is 17.9. Do you calculate all the RLA numbers to determine the demands amperage? I have a 150A 3 Phase panel and this is design as you go so I am making sure these RTU's will be ok in this 150A panel. I also have a 175A panel available but its easier to feed out of the 150A.
