Is this a violation???
DownRiverGUy
Canton, MI
Ok so ignoring the workmanship issues and any issues with supporting the conduits that feed this monster.... would you consider this a violation? :D
If so please cite what section.
While I would die a little inside if I saw this I am not sure if it is a code violation... just a great example of wasting a lot more time/material doing something the wrong way.
steve66
Illinois
Engineer
Job specification: Provide a NEMA 1 junction box with 96, 3/4" knockouts.
Contractor: No problem. I've got it covered.
Steve
iwire
Massachusetts
That is an old picture that has been floating around.
If all the boxes where facing the right direction I would say no NEC violation.
314.22 surface extensions - wiring method shall be flexible for a lenth sufficient to permit removal, to provide acdcess to the box.
300.15 (A) covers shall be accessible after installation.
312.5 (A) openings to be closed - conduit connector in bottom box
314.25 each box shall have a cover
314.28 (C) covers compatible with the box
314.72 (E) suitable box cover and readily accessable
410.22 outlet boxes to be provided with a cover
Some where I rember being told that piping from an extension ring is not allolwed. It may be a local thing. So then what about the box which allows attachment to a one gang opoening?
iwire
Massachusetts
Agree
Agree
Agree
Kind of a stretch in my opinion, all places for covers are closed.
Not unless those boxes contain conductors over 600 volts .... and I think we all hope they do not.
Applies only to lighting outlets, see 410.1
I think it is just a myth.
Not following you.
WDeanN
The picture is upside down. Flip it over, you can see the to of the sheet rock wall.
I see what looks like emt running across the top of a wall, but I don't believe that they are using wooden joists to support a metal beam... , or that those other wires are held up with spring tension...
