Have an upcoming job at a vegetable processing farm (Larger type Barn). The incoming service is a corner grounded Delta The main disconnect has two 600 Amp fuses. B phase is connected to earth thru the grounding lug in the main disconnect. First question, should not B phase be connected to a third fuse for short circuit or overload protection?
The barn has 3 small transformers to pick up various 1 phase loads which are blowing fuses during peak season.
The farmer has purchased a used 300KVA generator, transfer switch and 112.5 Delta to Y transformer. The salesman designed it so the generator would produce power transformer would take it from Y to delta then to the transfer switch.
I would like to use the transformer to take care of both Delta to Y and to pick up the load for the peak season 1 phase.
To accomplish this many of the 3 phase motors will have to be connected to the Y output.
Upon speaking with the refrigeration tech that brought up two points that has me questioning the design.
1) He spoke of some of the 3 phase motors not being able to work on the star system.
? Is the star the same as the Y or could he be talking about something else?
? Aren?t 3 phase motors designed to work on both Y and Delta?
2) He spoke of motors working better and longer life if on a Delta system any truth to this?
There are many 1 phase 240volt motors on the 3 phase delta system.
I will check all 3 phase motors for proper phase rotation and insure they have three conductors all ungrounded and an equipment ground.
Is there anything that jumps out as incorrect?
