I'm just curious to find out what code violations everyone see in this panel. It's fed by a 100 amp breaker in the main panel.
The larger white?...
I can't tell what that white wire is doing.
Is that a green hot wire?
Parallel conductors smaller than 1/0
They're not necesserily parallel. One could be feeding the panel, the other going elsewhere.
White wire is ground for GFCI breaker
Green wire is the noodle for the GFCI-protected circuit.
This is the interconnection point for a solar system we are selling to the homeowner. Fortunately, we get to tear this mess out and start over if he decides to go with us.
Is that two runs of Greenfield on the left side?
348.12 Uses Not Permitted.
FMC shall not be used in the following:
(1)In wet locations unless the conductors are approved for the specific conditions and the installation is such that liquid is not likely to enter raceways or enclosures to which the conduit is connected
Looks like they installed it with the lap edge up :roll:
Otherwise, its usage is debatable.
Water can enter the FMC, it just cannot enter the enclosures or other raceways it is connected to.
I have no idea what it terminates to and whether it is arraigned to drain into an enclosure. Just sayin, looks suspect from my armchair.
...and lap edge up allows water (rain, for one, being an exterior location, by the force of gravity and/or inertia) to enter the FMC and very likely wil run into the load end enclosure or raceway (judging by how it appears in the second picture).Water can enter the FMC, it just cannot enter the enclosures or other raceways it is connected to.
