indoor/outdoor coax
eds
I would like to slab my tv runs in a large residence that we are doing. I cannot find a wet location coax that carries the correct ul listing. I have checked colemans website (what supply house carries) without any success, can anybody recommend a couple manuf to check out
iwire
Massachusetts
Are you looking for wet location coax because you want to or because of the NEC?
The NEC does not require wet location coax.
eds
I have come to that same conclusion, have found cable for direct burial or wet location but not listed for inside use. One question what will happen if coax that carries a cm listing is installed in conduit under slab.
Volta
Columbus, Ohio
It'll be fine for a long, long time if it is a good PVC covering (no cut or splits).
