Is there anything wrong with this design scenario?
30 hp, 480V, 3 ph motor fed from a 100A circuit breaker with a 60A local non-fused disconnect. Wire size is #6 & #8G.
Thanks
430.150 has that motor at 40 amps
40x1.15= 46,,,,,so a 60 amp disco meets the requirement 0f 430.110 and the 6's assuming they are copper are ok.
EDIT :sorry chris,,,you're too fast
Can we assume there is a motor starter (with overloads) in there somewhere? You aren't planning on using the disconnect to turn the motor on and off are you?Is there anything wrong with this design scenario?
Thanks
