stew
- federal way,washington
my load calc skills are way rusty. need some guidance. office spaces which are now to be remodeled with no load change. 1028 sq ft. hvac loads are 3 ton pumps @ 28 a 208 v single phase w 60 amp elec heat back up. the only other loads are bath exhuast fan lite combos.thes now have 125 amp 3 phase 120/208 volt feeds. They may not even require load calcs on this as it is fire damage repair in like kind with no load change but I want to be prepared if I am asked to supply a calc. the heat does not run when the heat pump runs which is what I am not sure how to treat.
