A/A Fuel GTX
- WI & AZ
- Electrician
I have a MWBC feeding two GFCI recepts over a kitchen counter top. One recept is on one leg and the other is on the second leg. Common neutral and no load side connections. There is a range hood with light and two speed fan connected to the line side of one of the recepts. Now the strange thing..........the fan on either speed trips one or both of the GFCI's only when the switch is placed in the OFF position. The light works fine and is not a factor. When the fan is turned to the on position, it will run for hours but as soon as it is turned off, the trip happens instantly. I'm stumped on this one...........
