A/A Fuel GTX
- WI & AZ
- Electrician
I have about a 100', 240 volt feeder that will be direct burial URD. Is there any problem dropping direct burial coax and cat 5 in the same trench?
In your case the question that begs an answer is what is the CAT5 for?
-Hal
I would check with the AHJ. I do believe that it is a Code violation. You wouldn't run those three items in the same pipe, would you?
Even if it's not a code violation out by you it's probably really not good for the voice/data cables as far as interference.
