What is the minimum voltage rating you can use for a circuit breaker at a given voltage?
I think there was a rule I heard that it cannot be rated any less then the L-G voltage of the particular voltage it was being used on?
For example can a 120V breaker be used on a 480V circuit? From what I heard above it sounds like the breaker would have to be rated for at least 277V to be used on 480V?
However a 120V circuit breaker can be used on a 240V circuit because L-G on 240V circuit is 120V.
