100422-0844 EST
Put some monitoring equipment on the circuits to see what type of signal occurs and timing. Monitor voltage and current of each phase, and neutral, and maybe the EGC.
The design of your system will really define what you need to monitor. I would suggest you want 1 second sampling plus some instantaneous information. The 1 second sample rate will produce large files of data.
You can not reasonably store relatively instantaneous data for very long and therefore this monitoring should have some thresholding limits to control when data is saved.
