hrlyman
- California
NEC Article 700 pertains to Emergency Systems and other types of required "Standby" systems. I am trying to find information on "Prime" power system requirements which I dont see anything specific in any part of the NEC. Any other ideas for regulations or standards?
This is a 6 megawatt prime power system using 6 - 1 meg 480V generators. All of the gens will synch to a main low voltage bus and be distributed by CB to a step up Transformer to 12.5kv. The high voltage (secondary) will come back into a high voltage fused distribution cabinet and go out to loads. There is no interconnection with any other utility sources, no co-generation, no transferring of power, this is the main source.
The one question that has come up is if the synchronizing circuit for each genset has to be automatic or if it can be of the manual type? Does anybody have knowledge of any code restrictions or standards that relate to this?
Thank You
Thank You
