Input voltage is the designed, rated and safety agency approved nominal voltages that the supply will operate and produce the proper output.
The operational voltage is the voltage span that the power supply will function at and produce an output voltage within a certain tolerance.
As for your planned use of the 260 volt input voltage, I wouldn't do it, one minor surge and things can start smoking with the power supply or its connected load.
