knoppdude
- Sacramento,ca
Does anyone know the reason behind the change in the 2005 NEC that prohibits using NM cable above drop type ceilings in non residential occupancies? I am wiring a used trailer for use as offices, and the existing wiring is romex above the ceiling. I was told to run feeders overhead using NM cable, but as I read the NEC, it has to be protected by some type of raceway.
