Sudo cheap check, if the Client will pay for the servicing...
I think I'd run a fish through to the other end then attached a 4' large knotted rage and pull is back through just 3/4 the size of the hole, then go have the rag chemically checked.
Attack the rag to the side of wire or meter tape. Just be ready for the evidence,
Then, I'd pull a plug cleaner through, on meter tape. (also doubled ended) So if you get stuck you'll know where to dig!
I don't know what a session on a mass spectrometer is; but that'd be the fastest test around !
If your in an industrial situation, You might go back againest the weather records and note rain fall amounts... just a thought.
Good Luck!
