On a 480V High resistance grounded system what will be the system L-G voltage readings during a fault on the two unfaulted phases during the occurance of a ground fault on the 3rd phase? Will the L-G readings on the two unfaulted phases become the L-L values or will they stay the nominal L-G values?
I know that on an ungrounded system the two unfaulted phases will have L-G voltages equal to the system L-L voltages during a fault on the third phase. I'm not sure what happens though when a resistor is involved between neutral and ground.
