I have a customer who has purchased a lathe for his garage, a 3-phase, 220 volt, 7.5 hp Summit. It shows 7.5/6.1 FLA on the name plate. I haven't seen it but he said it was made in the late 70's and has a pretty complicated control system. He also has purchased a Phase-A-Matic phase converter; 4-8 hp, 22 FLA on the primary side.
I have never wired a phase converter but my first thought, without seeing any of this equipment is that it has to go between the contactor and the motor; it cannot feed the entire lathe since the control voltage is derived from the mains. He did say that only the big motor runs on three phase, the coolant pump has it's own single phase cord and plug. Am I on the thinking correctly.
Secondly, there is only one 20 amp circuit serving the garage so obviously that has to be upgraded. It is approximately 30' from the 150 amp house panel to the location in the garage where the new panel would be located. Plenty of spaces available in the house. I would like to put a 100 amp, 8 space loadcenter in the garage or maybe slightly smaller.
The lathe runs off of a clutch and he says that the motor starts unloaded. Should I be concerned about "browning out" the house when that lathe starts?
Any other thoughts would be welcome as well, especially concerning the phase converter. TIA
