transman2
- Brooklet,Ga.
Is it legal by code to run the grounding conductor of a AC multi conductor cable seperate on the outside of the cable.
300.3 Conductors.
(B) Conductors of the Same Circuit. All conductors of the same circuit and, where used, the grounded conductor and all equipment grounding conductors and bonding conductors shall be contained within the same raceway, auxiliary gutter, cable tray, cablebus assembly, trench, cable, or cord, unless otherwise permitted in accordance with 300.3(B)(1) through (B)(4).
(2) Grounding and Bonding Conductors. Equipment grounding conductors shall be permitted to be installed outside a raceway or cable assembly where in accordance with the provisions of 250.130(C) for certain existing installations or in accordance with 250.134(B), Exception No. 2, for dc circuits. Equipment bonding conductors shall be permitted to be installed on the outside of raceways in accordance with 250.102(E).
transman2,
Does AC mean alternating current or air conditioner? I ask because I got caught in a HVAC problem for a required receptacle once.
DARUSA,Armored Cable !!!!
Take a loo of 300.3 B
DARUSA,
I realize that AC could also mean Armored Cable, but unless this is 517 app, as Volta suggested, the OP has a grounding conductor system that is sufficient.
I merely wish to establish what the term "AC" is in the OP's context.
AC means alternating current and the cable is a 4 conductor type SOW cord being used for 3 phase system.
