se cable use in pvc conduit
rosie06
w hen using pvc on a outdoor service as a complete system to the weather head can se cable be used inside the conduit maybe 15 feet?
erickench
Brooklyn, NY
If you mean running a pipe to a weatherhead then it's a service mast. Usually it's 2" rigid metal conduit. Check your local codes and the power companies requirements.
A/A Fuel GTX
WI & AZ
Sure, as long as the point of attachment is fastened to something other than the PVC riser. Having said that, I don't know why you would want to do that. Why not THWN from the weatherhead to the meter?
electricmanscott
Boston, MA
This is not always true.
I consider a "mast" when the riser runs higher than whatever it is fastened to. That's generally the only time I see metal. Otherwise PVC or SE cable is used.
