We have been grounding panels for years. This year our local inspectors want us to ground the meter first then ground the panel, they said that is what Entergy that was wanted us to do this so they added this their inspection code list. I have been trying to discuss this issue with them with no luck. I can't find it in the code book that the meter has to be grounded as long as panel is grounded with rigid conduit coming through wall and binding screw. Even if you have an outdoor panel, and if you come out and ground the meter, the conduit should be the bond for the panel. You should not have to also ground the panel too. Can someone please inform me if they are aware of any changes to the code on this issue?
Thanks.
Thanks.
