Question: Would a switch loop be considered a set of travelers with a switch leg to a three-way or 2 sets of travelers going to and from a four-way switch where a return wire must accompany a hot in absence of a neutral?
Code Article: Three-way and four-way switches shall be wired so that all switching is done only in the ungrounded circuit conductor. Where in metal raceways or metal-armored cables, wiring between switches and outlets shall be in accordance with 300.20(A). Exception: Switch loops shall not require a grounded conductor.
