mkgrady
- Massachusetts
I plan to install baseboard heat in an unheated beach cottage in Mass. The cottage is slab on grade and all walls are finished with wood paneling, making snaking wires pretty difficult. I can drop down from the panel to the first heater and put a baseboard t-stat in it. I assume I will have to stop at the first receptacle because I am unaware of a ebbh that can be run under a receptacle.
Next, I want to put another ebbh a few feet away and run for several more feet until I get to the next receptacle. I want to do this until I have enough footage to heat the room. It will take about three six footers. I want to run really attractive 1/2" emt between the units.
The heat will not be even throughout the room because it will all be on one side but the homeowner doesn't even care how it works. He is adding heat as a requirement of refinancing the mortgage. He plans to almost never use it.
The question is, is there a ebbh made that would allow for installing conductors through the unit to feed the next unit(s)?
