laketime
One last time, from the meter to the panel for a single family dwelling, do you need a neutral wire? I have been told both ways by the AHJ. One guy says you need the neutral bonded to the ground at the meter and pulled with the ungrounded conductors to the house. The other says you just pull the ungrounded conductors from the meter with the grounding electrode conductor, then you "create" the grounded (neutral) conductor at the panel. What is the correct way?:-?
