- Massachusetts
Larry, I have no idea what you are trying to say.
If I lose the neutral between the source and say a standard home the service enclosure and all things connected to the EGC will be at a raised potential relative to the earth.
This is exactly the same situation as losing the neutral to a detached structure that uses the grounded conductor as the grounding means.
