appliance problems
laketime
Dryer broke about 3 weeks ago, electrical part problem (3 yrs old) now dishwashers heater seems to not be working (1 year old). Could this be a power quality issue (spikes)? Would a whole system surge suppressor be use full in a case like this?
laketime
could be crappy foreign made crap. my dryer cost $900 and needed repair after 3 years. my last dryer cost $250 and lasted 18 years and never had a problem with it until it just fell apart.:mad:
MJW
I thought I was being smart by buying a washing machine with a stainless drum. After 10 years the drum was like new when the tranny went out which cost as much as a new machine.
cadpoint
Durham, NC
It's time to talk to the neighbors, see if they had any problems, when and what happened!
If everything is 100% to your meter, a bus surge surpressor might add some piece of mind. This is the cheapest at about $35.00, the ones that are self contained are quite a bite more expensive.
Maybe you got a Monday or Friday appliance, I've come to realize that in a lot of cases, I'm always on the wrong side of the percentages! :)
It doesn't bother me now that I know and just keep going...
growler
Atlanta,GA
Are the electronic components going out or things like heaters. Ciruit boards with IC chips are affected by surges more than say a heating elements.
Low voltage won't hurt a heating element it just won't get as hot. If you start having trouble with digital electronic components in your house then you are having surges or spikes ( or could have ).
So what exactly was wrong with the dryer?
What is wrong with dryer.
Not sure if all of them are this way but have run into a few that have a thermal fuse located in the exhaust duct - if you have too long of a vent run or it is getting blocked or plugged it may open this fuse, which opens the main control circuit. Dryer will not run at all.
laketime
The dryer had a electronic part go out that controls the heating element.
