Yes you include both the neutral and ground wire in your conduit fill.In the heading of the annex it says number of current carrying conductors in rmc. does the number they give include the grouned conductor?
Raceway fill is a simple mathematical problem: How many little circles can you put inside a big circle?
"Current carrying conductors" is another beast entirely. The word "current" does not appear in Annex C at all.
That is my fault, Not annex c I ment to say table B.310.11
In tabble B.310.11 do you count the grounded conductor ( or common inD/C) as number of current carrying conductors
310.15(B)(4) Neutral Conductor.
(a) A neutral conductor that carries only the unbalanced current from other conductors of the same circuit shall not be required to be counted when applying the provisions of 310.15(B)(2)(a).
(b) In a 3-wire circuit consisting of two phase conductors and the neutral conductor of a 4-wire, 3-phase, wye-connected system, a common conductor carries approximately the same current as the line-to-neutral load currents of the other conductors and shall be counted when applying the provisions of 310.15(B)(2)(a).
(c) On a 4-wire, 3-phase wye circuit where the major portion of the load consists of nonlinear loads, harmonic currents are present in the neutral conductor; the neutral conductor shall therefore be considered a current-carrying conductor.
I don't see that Table in Annex B, however I may have what you want
B.310.15(B)(1) Formula Application Information.
This annex provides application information for ampacities calculated under engineering supervision.
