Hi,
My question centers on a proposed installation of a 24-unit meter pack (each pack contains a meter and disconnect breaker) for a multi-occupancy facility. More specifically, is a disconnecting means required before the 24-unit meter pack?
Figure 230.1 [230.1] implies that service-entrance conductors are located between the terminal box, meter or other enclosure and the service disconnecting means. This appears to be consistent with the definitions of service [100], service conductors [100], and service-entrance conductors [100]. Additionally, Section [230.70] indicates that the disconnect means shall disconnect all conductors in a building or other structure from the service-entrance conductors. Does this imply that a disconnecting means is not required before the 24-unit meter pack?
Any guidance is greatly appreciated.
Note: All provided [references] based on the 2008 National Electrical Code.
