I installed a timer for my exterior lights a while back (See Picture). I have 3 exterior wall sconces all compact fluorescent bulbs in them. My problem is that when they are on they all flicker together, its a very very fast single flicker but very noticable, and it does it every 10 seconds or so.
Since its rainy season down here in Florida (AKA Bug season) ive been turning the lights off at night manually to cut down on the the bugs nesting on my porch. I noticed that the lights rather then turning off, flicker on but extremely dim. Almost like when you dim a compact fluorescent bulb with a dimmer all the way down.
My question is, is this common with these intermatic timers, or do you think its a wiring problem? I have no idea how these switches work because unlike a normal switch where it breaks the current path, these switches just sit there and turn off when its time. Perhaps there is a mechanism in there that moves to break the current path, and maybe it is not moving enough?
Any opinions would be helpful as I will be fixing it this weekend
PS. See photo attached of the timer
