Good Morning,
I am inquiring into the proper Grounds Requirements for our 15kva Switchs and the Proper Grounding of 480 volt Switch Gear during our PM's. The gear is de-energized at the 15 kv level and both the Mains and Tie have been removed for testing.
After much investigation, on my part, I found that no manufacture will make approved grounding sets for the 480 volt gear. How do I work between grounds? Also, by applying approved grounds on the Medium Voltage Switchs, load side of the Fuses, switch LOTO'd, how does this protect me on the Secondary side of the Transformer? Any help would be greatly appreciated.
Thank You,
Jerry
Thank You,
Jerry
