When it says the EGC shall be permitted to terminate on grounding terminals in an outlet box used to enclose a snap switch does that mean the green screw can be used in a "bell box" with lets say forked stake- ons? Or does it need to be a individual terminal for each grounding conductor? Trying to come up with the best and easiest way to get the circuit from the panel(approx 100ft) away from the switching device and maintain a continuous ground per 680.23 2. Would running NM cable(12/3) and re- identifying one insulated conductor with green tape be an option? Thanks for any help you can give.
