brother
I know this came up before, and I was always under the believe that if the ground wire passes through the metal j box with the circuit conductors even if NONE of them are spliced, that the ground was required to be connected to the box. NEC 2008 250 148.
After reading Mike Holts comments he says its not if it just 'passing through' with no splices (circuit conductors is).
I still think it should be connected, After reading part (C) Met Boxes. What is your opinion of this??
