I have NEC 2008 on CD and have been searching to find where it may clearly (?!) state the rules for the following:
1. When an insulated bonding ('ground') conductor is run through EMT, on its own, that the EMT must be bonded to ground (e.g. via bushings at both ends, to either the 'ground' that is running through it or to a separately sourced 'equipment' ground - that is, a typical electrical ground as opposed to potentially tainting the 'isolated ground' which is running through the EMT).
2. That EMT may be used on a rooftop installatoin, e.g. power running across a rooftop (on supports of some sort) to an equipment cabinet. 'Standard' EMT I gather has a protective coating of sorts (light galvainzing for example). I also think that 'compression' (somewhatever watertight) fittings must be used... An engineer (eek!) stated that only RIGID metal conduit may be used on a rooftop - all electricians I talk to disagree. (Let's leave Sched 80 PVC out of htis discussion.)
Tnx!
Tnx!
