Chev
Master Electrician @ Retired
- Mid-Michigan
- Retired Master Electrician, Formerly at Twin Lakes Electric and GMC
I have a nagging thought running through my head that tells me: "you can not feed more than 1 piece of equipment from a single disconnect." But I can not find any documentation to back my memory.
Scenario is, a small drill press and a grinder mounted side by side. The guys on the job want to come out of an altered interlocking weld plug disconnect (plug removed and replaced with a sheet metal "patch") and feed (480 volts) both pieces of equipment from the one disconnecting means.
I question the alteration of the weld plug disconnect, and the feed of 2 pieces of equipment from 1 disconnecting means, but am searching NFPA 70, 70E, 79, and SAE Stds. for Automotive Industrial Machinery and I can find nothing to say "they can't do that". Helpppppppppp! :-?:grin:
