Does anyone know where you can get Aluminum to Copper Twister Wire Nuts for less than $ 216.00 per hundred.
Thanks in Advance
The hack electrician from the housing projects made the mistake of letting me know which supply house to goto. I found two bags of OLD red 3m scotchloks that had the "listed" label AL-AL or AL-CU or CU-CU.. they look exactly like the modern day ones.. I'm keeping the label. to show any inspector. OLD stock is allowable. 5cents each. I have also seen old "MARR" "Canadian brand" a set screw style w/black plastic cap that was also listed.
Just hope you never have to defend their use in court, their listing expired many years ago.
Wire nuts don't have a sell by date.
These connectors expired, we still had some in the shop.
I have never heard of an expired wirenut?Is thier a use by date?
The wire nut was listed for use, you can look up the manufactures listing on the UL site, and you will see it is no longer listed.
At one time they were listed so the listing should follow that product I looked at the UL site and could not find were to look for products that were retroactively unlisted.
Yes they were listed, and were approved for the listed use, but once the manufacture drops the listing, and the sale of the product, I would not recommend using the product.
