jerjwillelec
- Nevada, IA
- Master Electrician
Sorry about that... I'm having another issue in a trailer home. The other day I was called out because a 15 amp breaker would not hold. I isolated the circuit and was able to get 90% of that circuit to work and I just chalked it up to a bad wire. Today I get the same call on another circuit. Of course we can't have two bad wires in the same trailer at the same time so I dug deeper. I found that this circuit when turned on immediately pulls 62 amps for 3 seconds and trips. I took (I think) all of the load off line and it does the same. The SE is a 3 wire from the meter ped. There is a groud wire which is not bonded to the Neutral in the Trailer loadcenter. There is approximately 42 ohms resistance between ground and neutral. You guys haven't failed me yet so I'm counting on you.
