Can a standard dimmer (Lutron Diva) dim an LED recessed fixture?
laketime Senior Member Aug 23, 2010 #1 Can a standard dimmer (Lutron Diva) dim an LED recessed fixture?
Dennis Alwon Moderator Staff member Location Chapel Hill, NC Occupation Retired Electrical Contractor Aug 23, 2010 #2 laketime said: Can a standard dimmer (Lutron Diva) dim an LED recessed fixture? Click to expand... Some can and some need an LED driver to dim which means you need a special dimmer.
MarkyMarkNC Senior Member Location Raleigh NC Aug 24, 2010 #3 Call Lutron tech support with the type of LED fixture you are trying to dim, and they'll tell you for sure what type of dimmer to use. Lutron has one of the friendliest, most helpful tech support lines you will ever come across.
B BScottSATX Member Aug 24, 2010 #4 some dimmers require a minimum load to be present or they will not operate. 25 watts i think.
Lady Engineer Senior Member Location New Jersey Aug 27, 2010 #5 The driver for the LEDs needs to be dimmable.
