bedwardsnm
I have 4 - 480VAC, 30hp motors. I am feeding a control panel from a 480V distribution panel via a 225A circuit breaker and 4/0 cable. The panel is approximately 200 feet away from the distribution panel. There will be a fuseless disconnect when the 4/0 comes into the panel. I would like to add a distribution block to reduce the multiple cables size. Then to my multiple starters which will have overloads (heaters) built on. Is the thermal overloads (heaters) sufficient protection for the wires between the distriubtion block and my starters or do I need to add fuses or a circuit breaker?
