mkgrady
- Massachusetts
A more fun question would be "How many inspectors would require a receptacle at an 11" counter? Then we could have a 500 count thread!:grin:
kitchens are hard, there's nothing to measure off of as a rule.......
I don't know about you, but I won't wire a kitchen unless I have a full set of prints....... plan, elevation and isometric views.
As for what to measure off of, I generally use walls.
Like someone else said, if you can tell the difference between an 11" counter and a 12" counter by looking at the plans, your a better man than I.........
I just read the numbers that are printed on them.
Thats cheating LOL
............, but you'll be working a lot harder if it ends up being 12".
Again, if you're willing to go off of something that some designer drew, you go right ahead. You'll only look smarter if it's really 11", but you'll be working a lot harder if it ends up being 12".
And I would charge accordingly. 'Cause that's where the money is.
Your almost right. It says you must have a receptacle within 2 feet. That works out to 4 feet max apart. Also says any counter 12 inches or more gets one. In good design i would hope you have it even on the less than 12 inchersIs there something in the code which will require an outlet every 2 feet for residental kitchens, or am I mistaken?
It's not needed, but you could have a can opener there too...you never know!
As stated above, it's a receptacle within 2' along the counter-wall line. I call it the 2-4-4-2 rule, which applies to any space 1' or more, as we're discussing.Is there something in the code which will require an outlet every 2 feet for residental kitchens, or am I mistaken?
If the prints say 11" and it ends up being 12" I call that a change order. But we all know that means nothing in the residential market. Most of my scales say, "Whatever my penstroke happens to be at the time." :grin:
