So are the gas enclosed switches and breakers mostly used on higher voltages, like 15KV?
Steve
Steve- Gas Insulated Switchgear (GIS) at 15 kV is expensive and does not save much space. At 27kV and above, the higher cost is offset by the smaller footprint. One supplier offers 15-42 kV SF6 insulated gear in 24? wide x 64? deep enclosures.
Another benefit comes from each phase being in a separate "pipe" enclosure, which is considered by some as a zero arc flash hazard design. All energized components are enclosed in pressure vessels filled with insulating gas. A phase-phase fault is impossible and phase-ground faults can only occur inside the pipe.
At lower voltages (<42kV) a vacuum bottle circuit breaker interrupter is used, surrounded by insulating SF6 gas. That avoids the production of SF6 byproducts from arcing.
Some owners are using the 38 kV gear at 15 kV because of the arc flash benefits and the decreased maintenance costs (20-year maintenance cycle, if manufacturer literature is believable.)
If you?re interested check out ABB, Siemens, AREAVA, Hyundai and other websites.
