This is the Dirty Little Secret about LED's. Once you take the driver/ballast wattage, along with the fudge of they only measure lumens in a focused spot for a milli-second pulse before the light heats up and decays, they are about on par with incandescent lamps with a terrible CRI
Its been a year or so since I looked into this, but I think I remember most of it.
The claimed efficiency (lumen per watt) is exaggerated or IMO misleading for 3 reasons.
1. They do not include the driver power.
2. LEDs have a very narrow beam of light and the measurements are are made on a focused at 1 meter. Move a few degrees off center and the brilliancy falls sharply.
3. When the measurement is made, it is with a cold lamp and only pulsed for a few milliseconds. LED output drops significantly after they heat up.
So when all be said and done, instead of say 130 lumens per watt as they claim, realistically they are in the neighborhood of 40 to 60 lumens per watt of low CRI heavy on Blue Light pollution.
So IMO they are a poor choice for interior area lighting. However they can be very good choices for task specific lighting like tail lights, emergency egress, head lights, flashlights, head lights, landscape, etc...
I think someday soon, the kinks and problems will be ironed out.
The specs I've seen do include the driver, and most of the drivers I've seen are in the over 90% efficiency range. Rather a lot of engineering goes into them.1. They do not include the driver power.
[...], instead of say 130 lumens per watt as they claim, realistically they are in the neighborhood of 40 to 60 lumens per watt of low CRI heavy on Blue Light pollution.
So IMO they are a poor choice for interior area lighting..
I believe if you go back and read I did say the true efficiency is 40 to 60 Lumen right? Although somewhat better than incandescent, it is not as good as quality CFL's and no where near Fluorescent T5 and T8 ratings. Our Federal Government will not even allow LED's to be used in any Federal buildings.Yes, 130 lumens per watt is fantasy at the moment, 40-50 is common.
Driver plus LED wattage. The spec sheet should tell you. Typically 3 watts for each 1 watt of LED power.
So if someone has some up to date info I have overlooked please share. My mind is old, but still open.:grin: Where it affects me is I now tinker with Solar PV Battery systems and even CFL's can be a problem when ran on inverters and using low quality CFL's. A 13 watt CFL through an inverter can consume up to 55 to 60 watts from a battery. That is not good.
That is easy to answer. By measuring the DC current and voltage from the batteries feeding the inverter. Although I did make one error on the one tested. it was 33 watts from the battery.I am curious how your measured the wattage consumed?
