Red Wiggler
We have a disagreement here where I work concering "Working Space" and "Dedicated Equipment Space"...
I believe that an area behind a switchboard that will not require "maintenance", or "servicing" while energized should only need a minimum working space (30"). (Hinged doors should open 90 degrees)
Others argue this same area should be selected from Table 110.26(A)(1). Either a Condition 1 or Condition 2 because of the need to "test" voltage.
If necessary I believe you would be able to test voltage from the front.
What do you think?
What do you think?
